Shoul I Get Gtx aero itx 1060 6gb Single Fan Or nvidia geforce gtx 1060 6gb dual fan For Better Performance And LifeTime ?
And what are the differences between it. And thanks
Probably won't make a whole lot of difference, it's not a hot card and performance will be about the same. If you have a case with inadequate cooling, the single fan could be an issue. I'd get the dual fan either way if it'll fit
