GTX1060 thermals problem
Mar 29, 2018
Hi guys, I’m not sure if my rig has been running too hot.
This is the spec:
Ryzen 5 1600
Asus Prime B350 Plus
2x8gb DDR4 3000mhz corsair vengance rgb
Gigabyte gtx1060 6gb
Case: Phanteks P400S
CPU cooler: deepcool captain 240ex. Mounted in front as intake in push.
I have two 120mm fans as exhaust on top with dust filter removed and one 120mm fan as exhaust at the back.
My 1060 idle at 55~58 degree Celsius. When I play PUBG, it usually run at around 90% and 75~80 degree celsius. I’m running on 3 sreens which are all Dell U2312. I’m not sure if this temperature is normal for my rig because I’ve others running PUBG at around 65 degree celsius.
80 degrees isn't too hot, but it's getting up there. What percentage are the fans on the card running at? Maybe you need to set them to run a little faster, with something like MSI afterburner, you could set a more aggressive fan curve.
