GTX1070 with old 520W PSU - will it work?
legion285
Commendable
Nov 19, 2016
PSU in question is Corsair 520HX and apart from 1070 it would (now does) power i5 4690k@4.2GHz.
Will the power be sufficent for this GPU?
Will there be no problems with the connectors?
GPU I'm now using has 2x6pin.
1070 I plan to buy (Gigabyte G1) has 1x8pin.
My PSU has 2x6+2 and i assume this will work? It's not like there are other, new types of 8pins for GPUs?
The Corsair HX series were one of the best when they were released back around 2006/07. They're old, but their triple 12V Rails with a combined power of (3x18W) 54W will be easily powerful enough to run a GTX 1070 8GB. It is 100% fine on paper, and originally It's a great quality power supply. The only concern here is age.
The pins on the HX520 will work fine with any graphics card.
I've bought it around 07/08 and been using it since, no problems at all.
Ok, so now that i know it should work... What realistically can go wrong?
I mean if it dies I'll replace it but I'm kinda worried cos' of it's old age that it can kill other parts.
Is that kind of scenario probable? Should I replace it with something new?
It's possible, but doesn't have to be. The risk can be aging capacitors. Don't want those to choke first.
