Hey everyone, I have recently installed 2 PNY GTX 460 OC Cards, and have been having alot of heat issues. I manually set the fan profiles in MSI Afterburner to compensate, but it gets really annoying as well as disrupting to my roommate when the top card's fan is constantly running at 70% to make up for the heat. I have had no performance issues, which is nice, but is there any way at all to drop the temperature of the top card? With my mobo, the only 2 slots that can fit the cards are right next to each other, with barely any space in between the cards. My case has a side vent, but not a very good one. I'll post a full spec list below, but does anyone make side coolers, or some kind of velcro fan that i can just slap on the inside of my case? I've kinda run out of options at this point, so any ideas are good ones. Thanks so much if anyone can help!
Specs:
CoolerMaster Storm Case
EVGA E757 LE Mobo
2 PNY OC GTX 460 SLI
i7-920
3gb DDR3 RAM
2 WD Caviar Green 2 TB HD's
Corsair 750w Power Supply
Specs:
EVGA E757 LE Mobo
i7-920
3gb DDR3 RAM
