Hi everyone. Longtime observer, first time poster.
I recently ran into some issues with my EVGA GTX 560ti. After about 30 minutes of playing a game (league of legends, 40% GPU load); my card starts to steadily increase in temperature until the system locks up and shuts down.
My idle temps are perfectly fine even if I leave my PC on for days. (47C idle temp, card locks out at 105C, takes about 20 minutes before the card reaches 80C and steadily increases 1 degree per minute from there).
PSU: XFX Pro 850w
I took to time this evening to take the fans off the card and clean out all the dust on the heatsync/tower/fans. I pulled my tower out farther from the wall and raised it 2 feet off the ground in-case it was residual heat from being too close to the wall. Unfortunately I've had no luck after all of this.
Some Background:
The card is about 1 year old at this point. I've never had any issues.
OC:
920MHz Core clock
1950 Memory clock
1.025V
I even under-clocked the memory and core clock from the OEM values to see if I could get some better temps, and this also did not help =/
I tried contacting EVGA, and unfortunately I can not RMA (1 year warranted OEM model). Any suggestions?
Edit:
My tower:
NZXT Guardian
PSU: XFX Pro 850w
Some Background:
OC:
920MHz Core clock
1950 Memory clock
1.025V
Edit:
My tower:
NZXT Guardian
