GTX970 with i52320 - Help
TheNopeman
50
Current Specs:
Asus P8Z77-V LX
CPU: i5 2320 @3.0Ghz
GPU: Sapphire R9 270X 2GB
RAM: 8GB
PSU: Corsair 600w
I have been looking to upgrade my PC for some time with a £300($440) budget. I have been trying to determine the best way to spend for performance for me. I have been looking at purchasing a new graphics card, and my eyes turned to the MSI GTX 970. I know the GTX 970 had its whole 3.5GB ram thing but I can't see any better card for the money. I figured upgraded my GPU would be a great way to boost my fps and performance, however I'm pretty sure my CPU is going to bottleneck on a GTX970. I was wondering on whether I should upgrade my CPU first or go for a GPU upgrade first? And if so are there any better GPU's that would outperform the GTX970 for £300?
Upgrade the gpu first, you might find that your cpu is still fine for a while.
No, gtx 970 is a good value. If you spent less money, amd is usually a better price to performance.
