GTX980 Low FPS in CSGO with "Low" GPU and CPU usage
MrStifl
Hey!
So my problem is, every time I play CS:GO i only get about 120FPS(it often drops down to 14! FPS) when it only uses 50% max of the GPU and ~70%-91% max of the CPU.
I have a GTX980 and an Intel Core i5 3570K Overclocked at 3.8GHz.
The temperature of the GPU is about 60°C in midgame and the CPU is also at about 60°C.
My Ingame Setting are all at High with a Resolution of 1920x1080.
I play with a 144hz Asus Monitor and 2 separate Monitors(for Teamspeak etc.).
It only happens in CS:GO! I already tried the Benchmark test: Heaven DX11 Benchmark 3.0. With the benchmark tool it reached 99% usage all the time.
I really hope you can help me! Thanks!
