GTX980 Windows 10 1511 Problem, I need help please!!?
arq1999
Commendable
May 9, 2016
13
Hi,
So around 8 month ago I build a Pc, and everything was pretty good. But recently I update my windows 10 to build 1511. From that moment and getting notifications of the GPU crashing when its not, everything seems running fine. I use the DDU to reinstall the GPU, but did not affect anything. So this is my first build and I'm just a bit scared. Is this normal? and if not how can I fixed?
Operating System: Windows 10 Pro 64-bit
Ram: 16 DDR3
Processor: Intel i7-4790K CPU @ 4.00GHz
GPU: Nvidia GTX980
Please help.
Sorry for my bad English.
Hi,
Have you tried doing a clean install of the graphics card driver?
- Go to Device Manager and uninstall the Nvidia graphics driver.
- Next is to open Programs and Features then uninstall anything related to Nvidia.
- Once completely uninstalled, download and install the latest driver.
- Here's the link: http://www.nvidia.com/Download/index.aspx
- Reboot the laptop once the latest driver has been installed.
- After the reboot do test it again and see if the same problem will persist or not.
Latest posts
