Hello everyone,
I am planning on getting myself a new gaming rig soon. Need some advice regarding certain components as I do not know much on the tech front, only have some very basic knowledge and this will be my first serious gaming rig.
Plan on getting Gigabyte G1 980TIs (Dual SLI) for graphics + 32gb RAM (Gskill ripjaws 4x8gb 2666MHz) + Crosair 780T casing
1) Mainly need advice regarding the motherboard+processor combo. If you could have a look here you will be able to see all the processor choices I have.
- I am primarily inclined towards the ASUS Rampage V Extreme as the MB, so seemingly the best choice of processor would be the intel i7-5960X. Is this correct?
- However, I have doubts regarding the 5960X being the best bang for the buck, purely for gaming performance. The price is quite steep as compared to 6700K or 4790K. Corresponding MB choices can be viewed here
In short, which is the best processor for gaming purposes - this will automatically reflect on the MB choice as well. Planning on taking best in class processor for the MB (and vice versa). [see link again]
2) PSU - recommended power supply by the supplier was CORSAIR AX1200i platinum 1200W. Again, I think that money can be saved there to a certain extent. I intend to OC the processor as well as the 2 GPUs "to a safe extent" (will be done by the supplier). Do not think I will need 1200Watts of power. So the next choices are: Crosair 1000 platinum, or Crosair 1000W Gold.
Kindly outline the difference between Gold vs Platinum certifications; also if 1200W is necessary, then I will go for Cooler Master 1200W gold (it is significantly cheaper, almost $100).
3) Cooling - for the cooling system, I chose the Crosair Hydro series H110i GT 280mm - but i do not know jack about cooling in a proper gaming system, just used some intuition to reach to this choice. Any comments or further suggestions are welcome, other options available can be viewed here
4) Storage - Samsung SSD840 Eco 500gb + Seagate 4TB SSHD 64MB Cache SATA 6.0Gb/s. Advice regarding the SSD counterpart will be helpful, other options that I have can be seen here
5) Display - for the monitor, I would only be able to buy a single display for now as I am exhausting most of my budget on the machine itself. Pretty inclined towards the BenQ 2730z. Any comments are welcome.
6) Any other advice regarding overall usability of this configuration, update capabilities etc. will also be appreciated. Also, if any new tech is coming soon and I should wait, please do let me know.
Thank you for taking the time to read this and sharing some golden advice, cheers!
