The DS3 uses all Solid capacitors while the S3 uses electrolytic ones that tend to last up to 5 times less than the solid ones. The life expentancy is of course lowered with OCing since it puts such a high load on the motherboard. RAID support is added for the futureproof ability of the motheboard. Seems like Gigabyte really went cheap on it...
While the Abit AB9 is only $15 more than the S3 and it DOES use this type of capacitors. Its got RAID support. The S3 has a FSB top of 500Mhz while the AB9 has a top of 600Mhz.
For the above reasons is why wusy didnt suggest it on its C2D OCing guide.
The S3's highest FSB is 600MHz, that's even on my mobo's manual, and I even double checked it in my bios. There is someone in one of the Singapore forum, achieved a 570MHz FSB on a S3, on a E6300, but of course with much better power supply, and cooling, and casing. For the capacitors, I made a phone call to my local Gigabyte supplier, and was told the difference in the capacitor isn't going to make a huge difference. This motherboard was designed to be an overclocker, the S3 would last at least 5-6 years, if running on a 24/7 daily basis. Unless if you're planning to have your computer switched on for 24/7 for the next 5-6 years, this motherboard isn't going to fail for at least 5 years, and Gigabyte's representative talking to me on the phone emphasized on their seriousness in quality control. Besides, even if your motherboard can last 5 years, that doesn't mean your other parts are going to, including your HDD, Graphic Cards, CPU, etc, some might break down before your motherboard does, and in 5 years time, these parts might go obsolete, replaced with newer technology. By then, the $631 you've just spent on your system today would have definitely served to VERY well, and it would be time to move on with better money spendings.
Another point would be RAID being future proof, and come at a cost (RAID mobo costs more, more HDD costs more), but if you're on budget, you can't be going for the best of everything. At the time being, non-RAID will suffice. In real world/economics, there's always a trade-off.
Wusy didn't suggest this motherboard, because his guide and mine are totally different. His was there to achieve highest overclock, without considering budget. Mine, would be to go as cheap as possible, and for the best system for the price. There is a difference in spending $2000 to get a 5GHz system, and a $600 for getting a 3GHz.
This PQI stick not only is $33 less but it uses the same Micron D9GCT chips as Corsair, therefore WILL perform the same. They run at 1.8v at the advertised specs, newegg got it wrong. Dual-channel has prooven a 3-5% improoving in real life apps so no worries about that.
By the way, here you stated that youre running them at 2.1v, now youre saying 1.9v?
For this point, I can't argue, you're quite right. Corsair has their RAM being sold for higher price. But I mentioned, this is the only low latency modules available at my local store, and have proven to my own experience to work perfectly with my setup. Other RAM modules might work better at a lower price, but I can't guarantee that they're going to achieve as well of an outcome as the combination I'm having. Again, I'd have to admit, I'm not perfect. At 3GHz setting, my RAM was indeed running at 1.9V stable. I had it set at 2.1V earlier to hit my maximum potential, which I'm now running at 3.367GHz solid rock stable, will attempt lower it down to see if I can run lower Vdimm stable, as soon as I have time to do a MemTest. These torture tests do take a lot of time, and I've spent countless hours reaching a satisfactory overclocking speed. Regarding the other thread that you just linked to from your reply is totally irrelevant to this thread, as that thread is totally experimental of what I'm doing (and going to do) and is not final, whereas this thread is results proven to work.
Just for your reference, this is what I had on my other thread, that you were talking about, the 2.1V Vdimm, was set for my 3.367GHz setup (481MHz FSB), not for this thread's setting of 3.01GHz.
Vdimm at 2.1V.
Vcore at 2.2875V
FSB at 481MHz (3.367GHz)
Idle: 45C
Load: 59C (9 hours Prime95 so far no problem, still running)
The above settings are still temporary, can't be declared as my final settings, as I might decide to overclock higher, or try to lower voltages of Vcore and Vdimm to check if they could go stable at lower ratings. I've just called up my local store, and they have just received the Mushkin 2x 1GB 4-4-3-10 DDR2-800. The price of course, are much more expensive, at $340, but could ensure that I go close to 3.5GHz, or even higher. Since the store is 2 miles away from where I stay, and I've spent quite some time there over the past 3-4 days, discussing stuffs, and buying computer parts, I might just drop by tomorrow and look at it. I might not be able to afford it anytime soon, but even if I can afford it, would I spend that extra money for that kind of performance is another question to be answered.
Considering that newegg just recently stocked a Leadtek 7300GT 128mb DDR3, I would pick the X800GTO for raw performance and the 7300GT if you WILL use the SM3.0
There will be no winner over the debate of 7300GT vs X800GTO. X800GTO has better performance, but lacks SM3.0 support, and vice versa. For me, I'd rather have that extra SM3.0 support, and a slightly lower raw performance. Benchmarks have proven that the difference aren't significant, and would save you a couple bucks. A couple bucks here, and there would eventually save you tens, and potentially hundreds in your final set up. Anyway, I'd have to rephrase, both 7300GT (DDR3) and X800GTO are excellent cards for their respective price. Choose whichever suits you better.
My biggest complain with the CoolerMaster is that its got a single, very weak 12v rail. This Raidmax PSU, uses the same hardware as Antec, its got more power and a stronger 12v rail. Cheaper, better, blue.
The CoolerMaster PSU's aren't the best PSU around, but they're considerably cheaper, and at least, we can trust them better than a generic brand. If you find a better PSU for a better price, go ahead with it.
I not flaming completly your setup, but you shouldnt recommend something based on only your experience. There are better things in the market that might be more suitable for other users. Youve got a good setup, no doubt about that, but im just trying to make it better Wink
The reason I'm recommending something based on my experience is, because it's proven to work. Other setups/combination might not be able to get you this results, or might even get better results. It's risk taken, and luck. My recommendation is 100% proven to achieve at least 3GHz with $631 spent. Like what you've recommended over the RAM and the PSU, and stuffs, you might be able to get a similar setup for only $600. If you do, congratulations. But if you don't, I can't be the one to be blamed, as there are no 2 different product in the market the are 100% similar, there is always a difference, whether significant or not.
