guide me to build my GAMING PC
Along
7
I know so little about computer so I need you guys to help to build my gaming pc
this is the specs of my pc I thinking to build:
motherboard - MSI MS7845 Z87-GD65-G INTEL Z87 S1150 MB
http://www.pcdepot.com.my/msi-ms7845-z87-gd65-g-intel-z87-s1150-mb-4719072295516
processor - INTEL CORE I5-4440 PROCESSOR LGA1150
http://www.pcdepot.com.my/intel-core-i5-4440-processor-lga1150-5032037054980
graphic card - MSI GF N750GTX-TI PCIE 2GB DDR5 128BIT
http://www.pcdepot.com.my/msi-gf-n750gtx-ti-pcie-2gb-ddr5-128bit-4719072328184
RAM - KINGSTON KHX1600C9D3K2 8GB-CL9 DDR3 RAM
http://www.pcdepot.com.my/kingston-khx1600c9d3k2-8gb-cl9-ddr3-ram-740617169256
hard drive - WD CAVIAR BLACK 1TB 64M SATA-6
http://www.pcdepot.com.my/wd-caviar-black-1tb-64m-sata-6-6693159191107
power supply - AEROCOOL STRIKE X 600W PSU
http://www.pcdepot.com.my/aerocool-strike-x-600w-psu-4710700953655
monitor - SAMSUNG 24in S24C350HL LED LCD MONITOR
http://www.pcdepot.com.my/samsung-24in-s24c350hl-led-lcd-monitor-6614156861770
chassis - C/MASTER K350 CHASSIS
http://www.pcdepot.com.my/cmaster-k350-chassis-4719512036938
and one more thing can you guys explain to me that DDR3 on motherboard and DDR5 on the graphic card. If it different does it mean the graphic card does not suit the motherboard?
I am from Malaysia and this is all I can afford to buy for now. My bugget in "Malaysia Ringgit" is around "RM4000" if in dollar I think it will be around 1000 - 1500 dollar. I check using google currency lol - https://www.google.com/#q=1%20USD%20to%20MYR
hope you guys can help me. :3
That is a well put build actually. Let me make it even better for you.
Replace some of the parts.
Cpu : http://www.pcdepot.com.my/amd-fx-8-core-8320-35ghz-am3-be-730143302531
Motherboard : http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
Graphics Card : http://www.newegg.com/Product/Product.aspx?Item=N82E16814131529
I think I am still under your budget. Your build : cpu+motherboard+gpu= RM1907.
My recommendation : cpu(rm 540=$165)+r9 270x gpu($219)+motherboard($133)=$517 which is RM1692.
So which still leaves you with RM300. So you can buy a nice cpu cooler with it.
I think this cooler should be enough : http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
I still think there will be few bucks left, if...
I still think there will be few bucks left, if components in Malaysia are a bit highly priced, which I think they are not, you can easily make it up with it.
