Guys i need help with my Watercooling Loop
CrackerGamerYT
Commendable
Sep 21, 2016
7
Hey Everybode im building my very own custom watercooling loop
but i need help with the reservoir, the pump and the fittings
this are my parts:
Blocks:
CPU: https://www.ekwb.com/shop/ek-supremacy-evo-x99-nickel
GPU:https://www.ekwb.com/shop/ek-fc-titan-x-pascal-nickel
Soft Tubing:
https://www.ekwb.com/shop/tube-primochill-primoflextm-advanced-lrttm-9-5-15-9-mm-crystal-clear
Radiators:
480mm: https://www.ekwb.com/shop/ek-coolstream-pe-480-quad
360mm: https://www.ekwb.com/shop/ek-coolstream-se-360-slim-triple
FANS: https://www.amazon.com/quiet-WINGS-120mm-Max-1500RPM-Cooling/dp/B00ECWKD6I/ref=sr_1_1?ie=UTF8&qid=1479234894&sr=8-1&keywords=be+quiet+120mm+fan
Dudes i need help with the parts missing, i know those radiators are gonna fit in my full-tower Case sooooo. HELP ME PLEASE.
1. the tube you listed is 10/16, these fittings are 12/16 - as you can guess it will not work.
2. I don't know how you planned your loop to look like, you need at least 10 fittings for the list you initially posted.
3. you might going to need some:
* angle adapters https://www.ekwb.com/shop/fittings/adapter-fittings
* splitters https://www.ekwb.com/shop/fittings/extra/splitters
* you also would be much better with drain port that helps to remove the liquid from your loop. https://www.ekwb.com/shop/fittings/extra/ball-valves
learn how to plan loop here:
https://www.youtube.com/watch?v=Q4PRtFTEAgA
https://www.youtube.com/watch?v=SR9jEczwCZ4
https://www.youtube.com/watch?v=dy9EqbKLDP0
in the last video you can see exactly what the drain...
1. the fans you chose are bad for radiators. they are not static pressure optimized. the Noctua NF-F12 are much better option.
2. there is new (better ?) flex tubing from EK - https://www.ekwb.com/shop/ek-duraclear-11-1-15-9mm pick the sizr that you need.
3. CPU block - get the standard supremacy evo - it's identical, but comes with a lot of different mounting staff that may be useful in the future builds.
I like the D5 pumps - they are quieter and cooler. https://www.ekwb.com/shop/ek-xres-140-revo-d5-pwm-incl-pump
i use a smaller version of this and it's awesome.
in the last video you can see exactly what the drain port is.
Latest posts
