guys please help me
rajivpao
80
Friends please help me. Iam from india and my english is not so good.
I have replaced my zotac gtx 760 second time because last it was burned badly.
I want to know how to connect the auxiliary six pin power connector that I get with the graphic card with my psu.my psu is corsair vs 550 watt. Please help..
You plug in the 6pin part into the socket on the card, it only fits one way that presuming you have 2 x 6pin on the card. If one requires 8 pin then you use both parts of the 6+2 connector and put them in together.
If that is not enough google it, plenty of video guides.
Then why my graphic card burned last time ? This time I replaced my graphic card and again I installed it on my motherboard after that I run arkham origin only two minutes then I check the gpu temperature in firestorm it shows 77c.then I turnoff my pc.why this is happening please can you tell me. 🙁
