guys please help
Simply run it for a while. If you notice crashes, freezes or artifacts (weird things in the screen that shouldn't be there) then your card isn't stable. Also keep an eye on the temperature, above ~85 degrees Celsius is too high on most cards.
It's typically used for testing when you've overclocked your card, or if you're experiencing problems with your card.
