h-alpinia rs780l please help
higgins80
i have a hp pavillion p6597c motherboard is a H-Alpinia-Rs780L-uatx-605561-001 and i want to replace it but cant seem to find a motherboard that would be the pretty much the same across the board if i could get some help i would greatly appreciate it thanks
Motherboards are custom-made for HP and are therefore not available to the end user unless supplied/installed by HP as part of a warranty repair.
Replacing the motherboard would also mean you having to re-install Windows, but HP Factory Recovery Discs won't work if hardware on new board is not exactly the same as the old board.
