H100 cooling issues.
mattmace10
42
Hello all.
I am having trouble deciding on where to put my H100, do i put it on the bottom of the case drawing in cool air cool the radiator this is what i was really wanting to do untill i noticed that the pipes may not reach because of the GPU in the way, i can mount it on the top but hot air rises so wont it not be as affective..? i am using the case CoolerMaster CM 690 II Advanced. Any help with this would be greatly appreciated.
Matt :)
Ps: Wasn't sure where to place this topic.
This is how I have mine setup Outlander is dead on with having the fans push air through the radiator. The h100 can even do push pull if you were to push 2 fans on top and 2 fans on top and the bottom. Mind you this is a older photo. I since replaced my graphic cards with a gtx670. Also I don't use the stock fans that come with the unit because the air flow was strong with the cougar pwm fans and they are quite a bit quieter.
