Hi guys,
so i bought the Corsair h100i water cooler with my build but it doesn't seem to be working.
when i run prime 95 to do a stress test, after around 20 minutes or so, my cpu temp goes up to around 82C. Idles around 35C. my H100i temp idles around 30C and when my CPU is on load 100% it goes up to about 35C when my CPU goes up to 82C.
The odd thing is that no hot air is coming out the fans, the cooler pipes are vibrating (so it's definitely working).
I've updated the firmware to the latest as well and still no change.
I then took it off the CPU to see if it was attached correctly and it was. the thermal paste was all melted and distributed evenly across the CPU.
Does this mean i will need to reapply another thermal paste?
I don't know if it's just inaccurate temperature reading but i really do not want to risk anything melting.
I'm not even overclocking my CPU.
My gear:
CPU: i7-4770k
cooler: H100i
motherboard: Asus Maximus VI hero
Case: CoolerMaster Storm Stryker
Power supply: Corsair AX860i
Note: i have googled a hell of a lot and mostly people said it started working all of a sudden. one guy said it wasn't correctly connected so i screwed the screws in as hard as i could and saw a 3C drop in temp, nothing major.
Any help would be great, thanks!
My gear:
CPU: i7-4770k
cooler: H100i
