Hello. I just ordered some new fans for my h100i because the stock ones were awful, and im not 100% shure how to install them. Should I plug the new ones where the stock ones were?
Now that the unit is mounted, we will want to plug in power cables for both of the fans and the pump. The H100i has an integrated 4-fan hub which is where you will want to plug in your H100i fans. You will find two ports on top of the cooling unit, where you can plug in the included fan power adapter cables. Each adapter will support two fans, and by plugging the fans directly into the fan power adapter cable and into the cooling unit, you will be able to monitor and control the H100i fans through the Corsair Link V2 software.
