H100i: Need help, I wanna mount 4 fans (2 on each side)
Trez_YTR
119
I'm planning on buying an H100i but when I look at pictures of the parts, I see there are only 8 long screws provided (to mount the fan to the rad) but I'm planning on mounting 4 fans. 2 on each side for a push and a pull config.
Anyone got any suggestions? Or maybe corsair actually includes more screws? I don't wanna buy anything and not be able to use it fully if that makes any sense. 😀
Thanks guys!
Screw in two opposite corners of each fan, you dont need to screw down all four mounts.
That, and check the bundle of screws with the case. You should have long rad screws with it unless its a very cheap case.
Ahhh well I'm getting the Corsair 750 D so I guess there are long screws there?
