G guymarshall Honorable Jan 25, 2015 549 4 11,015 Jul 27, 2015 #1 I have a h100i but I was wondering if I could remove the pump and tubes from the radiator to install my custom tubing and pump.
I iamacow Admirable Feb 11, 2015 2,090 2 6,460 Jul 27, 2015 #2 yes...but if you have the money for tubing, pump and waterblock you can afford a real radiator. Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 Jul 27, 2015 #3 possibly but the inlets to the rad may be narrower than the tubing you will use could possibly adapt it but if the inlets are a fair bit smaller it will cause restriction personally i would just buy a proper good quality rad Upvote 0 Downvote
G guymarshall Honorable Jan 25, 2015 549 4 11,015 Jul 27, 2015 #4 Even if I didn't add more tubing, is there any way to remove the pipes and pump to get the coolant liquid out? Upvote 0 Downvote
I iamacow Admirable Feb 11, 2015 2,090 2 6,460 Jul 27, 2015 Solution #5 yeah cut it open lol Upvote 0 Downvote Solution
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 Jul 27, 2015 #6 guymarshall : Even if I didn't add more tubing, is there any way to remove the pipes and pump to get the coolant liquid out? you arent thinking of using the coolant? for one thing there wont be enough for a custom loop and you would need to filter it plus de ionised water is cheap Upvote 0 Downvote
I iamacow Admirable Feb 11, 2015 2,090 2 6,460 Jul 27, 2015 #7 I've seen people use the Pump part for a mini custom loop but never the reverse. Now if you think the coolant is running out, send it back for RMA. It has like 3 year warranty. When my H100 died, they sent me a H100i. Upvote 0 Downvote
