H100i replacement fans?
naurto75
77
Hey guys I just bought my self a define r4 and my pc is running great. The only problem is the stock fans on the h100i are quite loud. Im looking for a pair of fans that are quite but still provide adequate cooling as my fx-8350 is running at 4.6 ghz. I was looking as some of the NoctuaNf fans but dont know which model to get? Any suggestions or things I should know.
Anything important I should know about replacing the fans? Any really good suggestions price is not to big of an issue for me.
So these will work great with the h100i no mounting or compatibility issues and are they like same size as the stock fans or smaller since the stock fans barely fit in my case
how quite are they? I would be running them around 1000rpm when gaming, and around 400rpm when idle? I really want a pair of quite fans I just dont want my cpu temps to go above 62 or so. I want them to be very quite when im idle as that is when I will be watching movies I dont mind if they are audible while gaming I listen to music.
You bet ya it would 😀
Great Thanks for the advice will buy these when I get a chance. Do you think I should buy another two for my define r4? I mean the case fans are preety decent as it is/
