h100i v2 vs h80i v2 fit in sentey blade gs 6011
MUYchoto
43
Hi guys:
I have a question with a case Sentey Blade GS 6011. I need help to choose one liquid cooler i was thinking in a h100i v2 but i don't know if wiil fit in the case. So i thinking in the h80i v2 but if i can fit a h100i v2 will be better. Will fit the h100i v2? is the h100i v2 much better than a h80i v2? Thanks for any answers, have a nice day.
Case: Sentey Blade GS 6011.
You can fir a h100i there. The case has support for 2x120mm top fan, while the radiator of the h100i (which is installed at the top) is 240mm so it will fit. The fan (cooler) of the h100i which is mounted on top of the CPU is 120x120 while the max supported by your case is 150x150, so you can install the h100i.
However you can install ONLY h100i v2, the default h100i has a 40mm longer radiator which will NOT fit.
MUYchoto
43
Thanks for the answer, and the fans exhaust or intake with the h100i? because corsair says intake but the tops fans is better exhaust always.
Actually cited from corsair: "The fan installation can be done in multiple ways, but by default we would recommend having the fans mounted on the bottom of the unit exhausting air up through the radiator towards the outside of the case. "
like this:
