H100I V2 with Corsair 400C Case ?
tristan.martin564
45
Alright so i've purchased all the parts for my new pc build and was just having a look at the cases specs. Up front the Corsair 400C case can have up to a 360mm Radiator while the H100I is a 240mm Radiator. Would i be able to put the 240MM Radiator up front or will it have to go up top where a 240mm radiator would be able to fit ?
Just curious as i want to have it upfront in the case. Thanks!
~ Marto
That's up to 360mm (3x120) radiator on the front. The 240mm H100i is 2x120. It will definitely fit in the front.
From the specs at http://www.corsair.com/en-us/carbide-series-clear-400c-compact-mid-tower-case:
Radiator Compatibility:
360mm: Front only
280mm: Front only
240mm: Front or Top
120mm: Front, Top, or Rear
360mm: Front only
280mm: Front only
240mm: Front or Top
Alright thanks for clarifying. That's what i had thought but wanted to just double check. Thanks again!
