H105 Will fit on my NZXT Phantom Case?
insane1337
The title resume it all, i need to know if a corsair h105 will fit on nzxt phantom full tower case in PUSH/PULL configuration, do i have to mod the case, or do you recomend another wc? thanks
Yes it does but you would need to buy another 200mm fan for the top of the case its quiet hard to fit but it fits if you get the H100i it will give you all the bits you need ive got the case and it fits perfectly :)
@Louie
I currently have a 200mm on the side of the case, do you think moving it to the top ( making 2x 200mm top) will help with the radiator cooling?
