Question H110 PRO BTC Not posting (NO SIGNAL), keyboard light doesn't turn on
Dreagnout
Commendable
Feb 6, 2021
8
Hi,
I was mining with H110 Pro BTC like a year, all fine, but the motherboard stop posting on a random day, so I was thinking is the motherboard, change it, replaced with a brand new (another H110 Pro BTC), same CPU, RAM, all same components that worked for me last year, and the brand new keep without posting pluging the DVI-D port cable to HDMI display. If I plug a Microsoft Curve Keyboard, the CAPS Light [A] not powering, should power on, because when I connect that keyboard on another motherboard, that light turn on instantly. Anyway, when I plug on the same USB Port a pendrive, it's showing the light, so it's strange thing. Tried clearing CMOS, battery, and no graphics. Using the same DVI-D to HDMI cable that worked for me to show the display last year without a problem... On the display it's shows "NO SIGNAL".
GPU'S, PSU and GPU fan's working too, so they have power.
What can I do?
full system spec?
Triple PSU:
CORSAIR HX1200
CORSAIR HX1200i
EVGA 1300G2
(Their fans are running when Motherboard goes on)
CPU COOLER Nox Hummer H-212
Intel Celeron G3930 2,9 GHz Caja 2 MB Smart Cache LGA1151
Crucial RAM CT16G4DFD824A 16 GB DDR4 2400 MHz CL17
Display: Samsung S24F354
Remember: All components were working fine a year ago, it's not compatibility component's problem, all of them were working fine...
I can talk on Telegram if you wish for more faster communication.
