H110i GT Fans in push or pull for my case airflow.
willabyblen
95
Hi Guys,
I am going to install my h110i gt today and would like to know if I should install them in Push or Pull configuration? I have the radiator at the top of my case.
As for my case fans I have two intakes at the front of my case ( x 2 corsair AF140), one intake at the bottom of my case ( corsair AF120) and one exhaust at the rear of my case ( scythe gentle typhoon 120mm.)
Will the exhaust config be better to help with case airflow or am I better off getting the cold air from outside the case on the Rad?
Thanks
I would definitely recommend a push configuration (with the fans being below the rad) since if you went with a pull config you would only have a single exhaust which is not ideal. If you really wanted to you could do a mix of push/pull like this http://s29.postimg.org/g8mcvv6ef/config_6.png , but personally I think the push configuration would be just fine.
