I am not sure how to enable the front panel audio.
There's details in the manual about the nine pin onboard connector and talk about if you've got an AC'97 audio panel which I don't understand.
Would that be some kind of audio panel you can buy separately and fasten into your pc box when you're building a machine?
And does that mean there's some other kind?
And what's this other stuff I read in the manual about needing an HD front panel audio module? That's in order to enable 7.1 channel audio. Who needs 7.1 channels, I mean, what's 0.1 of a channel?
Right now I would just like my earphones to work. I plug them into the speaker plug at the back and they work but too faint. And the software doesn't offer any way to reconfigure for earphones - if that would make any difference.
Just would like the quickest simplest fix, for starters.
So what sort of connector do I need to get for that onboard connector?
And what other things should I get to know about in this respect?
