I recently bought a H115i, my case was to small so I went ahead and bought a larger case to fit everything, the Phantek Enthoo Pro. has been working perfectly until a few days ago when one of my radiator fans have been making an annoying rattle sound whenever the radiator fans ramp up. I have cleaned out dust and tightened screws. From what I have read so far I believe it is a resonance issue. The fans are currently sandwiched between the radiator and case, could this be the issue? Also if I am to buy new fans will I have to remove the coolant system from the cpu and case entirely to replace the fans in their current position?
