Question H115i pro won’t fit in cooler master full tower!
May 6, 2019
Hello, I bought a Corsair h115i cpu cooler for my i9-9900k. The tower I got for it was a Cooler Master HAF X Full tower. I read somewhere that it would be compatible but i started building it and doesn’t seem like so. I don't know what my best option is. I was planning to do a modification to the case and drill 4 new holes for the cpu cooler.
Case:
https://www.newegg.com/Product/Product.aspx?Item=9SIAHF595F5320&ignorebbr=1&source=region&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-Baifeide-_-Accessories+-+Case+/+Rackmount-_-9SIAHF595F5320&gclid=Cj0KCQjwtr_mBRDeARIsALfBZA6uhnyeK5tUybwYbyLQj4s7mg4CkTiXG2JN4Z0KEo1_SBofJTXromQaAuOYEALw_wcB&gclsrc=aw.ds
Cooler (version 2 fan slots (140mm):
https://www.newegg.com/Product/Product.aspx?Item=N82E16835181138
Here are links to what the case holes currently look like:
https://imageshack.com/i/plTMRfQGj
I plan to make the holes left of where the holes in the cpu cooler is currently at in this picture:
https://imageshack.com/i/pnmQ0KkDj
Does anyone have any better ideas? Thank you for your time and assistance!
May 6, 2019
Won't fit. 280mm is too big. Can only fit 240mm max. The largest cooler that will work will be the 110i.
PS. You didn't just recently buy that case, did you?
The 110i is also 280mm.
I got the case a long time ago. I can't really find any liquid cpu coolers that are 250mm
