Question H115i RGB Platinum CPU cooler 280MM CPU cooler compatability?
chancemitchell
74
9
4,645
I bought the H115i RGB Platinum CPU cooler 280MM CPU cooler a year or two ago to cool my intel CPU. I upgraded to a x570 AORUS ELITE WIFI and Ryzen 3700x. I was under the impression that I had the AMD bracket and it would be an easy switchover. I quickly realized I don't know how to mount my cooler with the brackets it came with. I read that you can order a bracket that is compatible but when checking I realized the bracket is a circle and my cooler plate is a square with edged corners. When I search for videos on the installation they all show circle CPU plates. Did I have like a previous version of this cooler? Is it possible to mount my MOBO and CPU or do I need to sell it off?
Thanks for input.
