[SOLVED] H150i Elite Capellix and front fans settings
Alrick
12
I have a Phanteks p500a and using the H150i at a top radiator. I have the three fans on the radiator on balanced and the pump on extreme. I also have the back fan on balanced as well. The three stock fans in the front are on full speed. The noise level isn't loud nor bothers me, but I was wondering is this a good setup or unnecessary?
You're the only one who can really answer this.
Everyone has different level of hearing sensitivity - what you're comfortable with, another may not be comfortable with, and so on.
If you're comfortable with the performance and noise levels, there's really not much else to be said about it.
Reactions: Alrick
