H440 fan replacement
tylerdrumr
18
What is a good fan to replace one of the stock front fans (120mm) on an H440 case?
Should I replace all three, or will I be fine just replacing the one?
Fans I have considered from other posts:
Corsair SP120, Corsair ML120, Noctua NF-F12.
Background: The other day when I was cleaning out my case I did something stupid and broke a fin off of one of the front 120mm fans. Warranty replacement is out of the question. The fan setup is currently just the stock setup (3 120mm pulling in front, and 140mm pushing out the back.)
MERGED QUESTION
Question from tylerdrumr : "H440 fan replacement"
Yeah I wouldn't have a problem doing that. I just figured if there was an upgrade to be had, now would be the time to do it.
