h440 owners help!
jeslinker
7
I was looking into the H440 case by NZXT for its aesthetics, water cooling capacity, and its silent operation, but im wondering about a few things. It has white led accents, even on the black and red model of the case, and i was wondering if it was possible to change out the white led located behind the PSU shroud cover, and the leds located above the rear i/o ports and pci brackets, by some means of modding. I would either solder red led instead of white ones, but im just wondering if its at all possible, and you owners could give me some valuable insight to the issue.
Second one, im wondering about how well the front and top fan mounts would accommodate 360mm rads? or should i opt for a 360mm in the front, and a 280mm in the top??? thanx in advance guys!
I run an NZXT H440 with a Kraken X61 and there's plenty of room for it. I am not sure if it's possible to switch out the LEDs, maybe with some creative modding but that could also possibly be warranty-voiding.
