H5 Ultimate screw problem
cullenz
8
So I've just recently purchased the H5 Ultimate for my first build.
I installed it once, went perfectly smooth.
I then later had to take it out and reinstall it because of a case fan cable getting stuck in an unreachable spot due to the H5's position. I then try to reinstall it, and it won't screw in. The screwdriver catches and the screws turn, but do not look like they are going anywhere, and do not mount.
What do you think is the problem and what would be the solution?
