Hey everyone,
I think this will be the final question I have for my first build...
I setup my H60 at first using only the stock Corsair fan that came with the cooler pulling in cool outside air. My CPU idle temps are around 26-30c with this setup. I then thought that adding the stock Cooler Master fan to make it a pull-push would be a good idea but my temps are the same. I then realized that the Corsair H60 fan probably didn't have the same specs as the Cooler Master fan such as RPM etc, which seems like a bad thing.
This raises several questions for me that I can't figure out and would like for you experts to answer
Here are the questions I have:
- Is it okay to use the stock Corsair fan along with the stock Cooler Master fan in the pull-push?
- Would it be better to buy two Scythe Gentle Typhoon (1850 rpm) fans (or any other better fans) and use those instead of either of the above?
- Is it okay to plug one fan into CPU_FAN1 and the other into CPU_FAN2?
- Is it better to setup the air-flow as intake (pull-push) bringing air into the case or exhaust (push-pull) to take it out of the case? (seems like intake so cooler air is coming in)
Everyone seems to recommend the Scythe's like these: http://jab-tech.com/Scythe-Gentle-Typhoon-D1225C12B5AP-15-1850rpm-pr-4501.html ... (Anywhere that has these cheaper or is this the best price?)
What do you guys recommend for the fan setup and whether intake/exhaust?
Hope I got the terms right ... still learning!
Here's a picture of the case (Sorry about the quality):
Also, here are the Cooler Master and Corsair H60 Fan specs that I could find:
Cooler Master:
Rear Fan: 120 mm fan x 1 / 1200 RPM / 17 dBA
Corsair:
Fan Dimensions: 120mm x 25mm
Fan Speed: Up to 1700 RPM
Fan Airflow: 74.4 CFM
Fan dBA: 30.2 dBA
Fan Static Pressure: 3.2mm/H20
Thanks!
Cooler Master:
Corsair:
Fan dBA: 30.2 dBA
Thanks!
