H60 with 2 fans
AMDAlexK
70
hello all, not that urgent but im kind of confused here. my h60 is loud. im going to buy 2 yate loons for it and hopefully it will run quieter. only question is how do i connecr 2 cpu fans to my motherboard so that it recognizes them as cpu fans and not case fans? my motherboard is an ASUS M5A97 LE R2.0. any help is greatly appreciated.. also, do you think that these will make it run more silent and more cool at the same time? thanks again.
-Alex
There are 3 headers at the top of the board, and you easiest option would be to use a y cable for the two fans.
The cheaper, quieter, and better performing option would be to get a better cooler. The H60 does not perform too terribly well, while remaining loud in the process. Something like the 212 EVO is about the same as two 120mm fans, and is much quieter.
