Just swapped in an h80 and the fans run maxed out.
Both fans 3 pin connectors are running to the waterblock, and then the 3pin from the water block to the 4 pin 'cpu_fan1'
I also tried plugging into the 3 pin 'Pwr_fan1'
Just runs completely maxed out.
It's actually more like ONE is running maxed out, and the other is just kinda going. I can't really tell. They're loud AF. SpeedFan shows them running at 2200 rpm...
I have an asrock fm2a55m-hd+ mobo
The 'speed change' button on the waterblock doesn't do anything.
EDIT: Unplugged one of the fans, and it got extremely quiet so one of the fans is running maxed out, and ones not. but Speedfan is still reading it at 2200rpm now 2300rpm lol...
EDIT2: If I unplug both fans. Whichever fan I plug back in first to the water block on the h80 runs maxed out, and whichever fan I plug in second, runs at almost no speed.
If I unplug both fans, speedfan still reads a fan running at 2200-2300 rpm. What is Speedfan picking up?
