I was considering buying the af120 led white to match the fans already in my 600T. However after some quick research I learned that the h80i radiator needs a static pressure fan to get air across the radiator better.
I get that in theory the SP120s on both the push and pull will yield the best results but does anyone have any experience trying an air series case fan as the interior pull fan on a radiator like the h80i's? I was hoping for a few things. First, improved aesthetics and secondly a quieter experience but if the AF120 is just too weak and hinders cooling performance too much then it's not worth the aesthetics upgrade if you now get where I'm going with this.
I have to get some sleep but I'll update with pics soon if that helps with what I'm saying.
Thanks,
Justin
Thanks,
Justin
