h87-pro, need help to find hardware for it
Daniel Ferreira
18
i want to use this motherboard, cause its good, it got crossfire, and supports i7 but on that site i dont know how to find it the best pieces, can you tell me the best pieces for it?
if posible i want 2 graphics of crossfire the max posible,
cpu i7
a drive whit 1Tera
and the max of ram posible on that slots.
and the cd player that matches on it.
all of it has you know must match whit the motherboard.
the motherboard is this one.
http://chip7.aeiou.pt/produtos/informatica/componentes/motherboards/mb-asus-chip-intel-h87-c2-sk1150-4xddr3-hdmi-atx-h87-pro.html
thanks for the help
Hi there, here's some VERY good pieces that will work wonderfully, for each section there's a top range option (Option 1) and a very good but less expensive option (Option 2)
CPU:
Option 1: http://ark.intel.com/products/75123
Option 2: http://ark.intel.com/products/75047/
RAM:
Option 1: http://www.corsair.com/en-us/vengeance-32gb-quad-channel-ddr3-memory-kit-cmz32gx3m4x1600c10 or http://www.amazon.com/Kingston-2400MHz-PC3-19200-KHX24C11T3K4-32X/dp/B00A771ZOQ/ref=sr_1_1?ie=UTF8&qid=1399710936&sr=8-1&
Option 2: http://www.amazon.com/Corsair-Vengeance-Desktop-Memory-CMZ16GX3M2A1600C10/dp/B006EWUO22/ref=sr_1_1?ie=UTF8&qid=1399711093&sr=8-1 or...
CPU:
RAM:
Option 2: http://www.amazon.com/Corsair-Vengeance-Desktop-Memory-CMZ16GX3M2A1600C10/dp/B006EWUO22/ref=sr_1_1?ie=UTF8&qid=1399711093&sr=8-1 or http://www.amazon.com/Kingston-2400MHz-PC3-19200-KHX24C11T3K2-16X/dp/B00A771ZJG/ref=sr_1_2?ie=UTF8&qid=1399711086&sr=8-2&
Hard drive: (For the hard drive I would have a SSD for boot drive, to increase boot time and a 1 Terabyte hard drive for storage)
Option 1: SSD: http://www.amazon.com/Crucial-240GB-2-5-Inch-Internal-CT240M500SSD1/dp/B00BQ8RM1A/ref=sr_1_3?ie=UTF8&qid=1399711303&sr=8-3 HARD DRIVE: http://www.amazon.com/WD-Red-NAS-Hard-Drive/dp/B008JJLXO6/ref=sr_1_2?ie=UTF8&qid=1399711399&sr=8-2 or http://www.amazon.com/Western-Digital-Cache-Drive-WD40EFRX/dp/B00EHBERSE/ref=sr_1_1?ie=UTF8&qid=1399711399&sr=8-1 (2nd one has a extra 3 Terabytes! )
Option 2: SSD: http://www.amazon.com/SanDisk-6-0GB-2-5-Inch-Height-SDSSDP-064G-G25/dp/B007ZWLRSU/ref=sr_1_1?ie=UTF8&qid=1399711194&sr=8-1 and HARD DRIVE: http://www.amazon.com/WD-Green-Desktop-Hard-Drive/dp/B006GDVREI/ref=sr_1_4?ie=UTF8&qid=1399711238&sr=8-4 or http://www.amazon.com/WD-Green-Desktop-Hard-Drive/dp/B008YAHW6I/ref=sr_1_1?ie=UTF8&qid=1399711238&sr=8-1 (2nd one has a extra terabyte for not much more)
CD drive:
Option 1: http://www.amazon.com/Asus-DVD-ROM-Internal-Blu-Ray-BC-12B1ST/dp/B004SUO068/ref=sr_1_1?ie=UTF8&qid=1399711642&sr=8-1
Option 2: http://www.amazon.com/Asus-Serial-ATA-Internal-Optical-DRW-24B1ST/dp/B0033Z2BAQ/ref=sr_1_1?ie=UTF8&qid=1399711676&sr=8-1 (Doesn't play blue ray)
Graphics card:
Option 1: http://www.amazon.com/XFX-RADEON-1000MHz-Graphics-R9290XENFC/dp/B00G2OTRMA/ref=sr_1_1?ie=UTF8&qid=1399711723&sr=8-1 (Please note I doubt crossfire will be needed for this card)
Option 2: http://www.amazon.com/XFX-FX777AZNF4-Edition-1000MHz-Graphics/dp/B007A44T42/ref=sr_1_1?ie=UTF8&qid=1399711794&sr=8-1 (Can have more in crossfire)
Hope all this helps!
wait, if possible just 1 question, its possible to get 2 graphics whit 2 gb for make crossfire, i dont know but probably its less expansive than buy 1 whit 4gb already cause all of it whitout the graphics will cost about 850 euros, so if the both coud be about 300 or something like that woud be better than pay 650 euros xD the second option its just 2 gb but give me your opinion :)
Having one card in my opinion is a better option for a few reasons:
1. air flow as there is more room and less wires connecting the two cards so cooling will be better.
2. Performance tends to be better on the single card because it has more features that allow it to work better "Such as 3D, more monitors for eyeininity e.t.c
But of course for performance having two 2gb cards (depending on the card) would have equal performance to one card as long as its 2gb GDDR5 RAM
Hope this helps!
