D darkfield0 Reputable Jul 19, 2015 4 0 4,510 Aug 3, 2015 #1 Does the Thermaltake Level 10 GT fit a Corsair H90 with a Push/Pull configuration on the radiator? Thank you!
Zerk2012 Titan Ambassador Oct 6, 2014 22,337 2,408 104,240 Aug 3, 2015 #2 http://cdn.pcpartpicker.com/static/forever/images/userbuild/117453.c9acff30830b7450f111733d98d623c5.6e510587080d404a064155031df0de9a.1600.jpg looks like it would be close. Upvote 0 Downvote
D darkfield0 Reputable Jul 19, 2015 4 0 4,510 Aug 3, 2015 #3 What about just a simple pull configuration as the rear exhaust? I mean I dont know if push/pull may not be necessary really Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,337 2,408 104,240 Aug 3, 2015 #4 That picture is that case and the H90 so yes and it looks like 2 fans will fit depending on the motherboard heatsink. Upvote 0 Downvote
