[SOLVED] Hackintosh sound issue on HDX16, need kext
Vengeance_
51
Most peoples sound issues on hackintosh is no sound. My issue is sound is stuck at maximum volume output, it doesn't matter what volume it is set at, it will output max volume, even on mute. I wonder if there is any kexts or drivers that will fix this? I also noticed that when connecting or disconnecting headphones or any external audio device, I have to manually change the audio device for it to work. Volume issue remains on all devices. devices include internal speaker system, dual headphone port, and Nvidia HDMI audio.
I found the solution! 😀
I used the following kext and it worked: http://www.osx86.net/files/file/1257-idt-92hd71b7/
Kext is designed for OS X Lion but worked on Yosemite!
