Haf 912 compatible case fans
crazypotatos
19
Hi,
I have been searching google for like an hour and I can't find the answer to my question. Which 200mm fans will work on the haf 912. If I look at the cooler master 200mm fans, the description says every other case they have except the 912 is compatible. So can someone who has the case let me know if this is correct or not? My idea for the fans was:
Front: 1 200mm intake
Top: 1 200mm exhaust
Back: 1 120mm exhaust
Side 1 120mm intake
I already have the two 120 fans that are in the case default, I was going to leave the back one there, and move the 120mm one in the front to the side and then buy two 200mm fans.
I'll be running an i7 3770k OC and a gtx 760
Thanks
Just to close the thread, I bought 2 of the Coolermaster 200mm fans (non-led ones) and I put one in the front and one on the top. They both fit fine. Just to note when you install the front fan: Get the longer black screws out of the little bag of screws that they give you, otherwise you can't put it in.
