R RahulMonkey Reputable Dec 30, 2015 150 0 4,680 Jan 31, 2016 #1 Can I use just both of the HAF Stackers instead of one normal case in the middle for one being an actual system and one being watercooling things?
Lutfij Titan Moderator Oct 7, 2009 61,482 6,863 178,440 Mar 12, 2016 #2 Yes the top module needs to be the rad box while the lower end will house your components. The only issue is planning out your build, this will indeed welcome restrictions and compromises on almost every front if you gain on the other. Upvote 0 Downvote
