Haf X Case Fans
mossie
8
I bought my self a Cooler Master Haf X case and bought an extra 200mm fan. When i go to install in on the the brackets on the top i can not close the top of the case. I noticed that the USB 3.0 cables got in the way. I was wondering if there is a way to install this fan on top of the computer. I gave up after and hour. While i am here i post what else is in my new build. I just have questions on the ram or anything else you notice that might work well.
Haf X
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225&cm_re=haf_x-_-11-119-225-_-Product
After market Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103072&cm_re=200mm_red_led_fan-_-35-103-072-_-Product
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171057&cm_re=silent_pro_gold-_-17-171-057-_-Product
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070&cm_re=2600K-_-19-115-070-_-Product
Mother Board
p8p67 Deluxe
Sorry no link do to recall
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
I would like to go with Corsair or patriot and about 8gigs
After Market CPU cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103089
Let me know what you think and how to install that fan on top of the case. If you would like photos i could try to post them tomorrow i have work for the next 24hours :hello:
