HAF X USB front panel
saiyanwarrior
9
hi, i just built a computer and i was wonder is there a way for me to make my usb 2.0 and usb 3.0 in the front panel to work i got the usb 3.0 to work by plug in the blue cable in the black but my usb 2.0 doesnt work
my friend told me that i can either use usb 3 or my usb 2 i can only pick one
HAF X and motherboard p6x58d premium
The HAF X comes with the 2 blue usb 3.0 cables attached that you can convert to usb 2.0 with a cable that comes with the case. The 2 usb 2.0 ports on the front should already have a cable attached that plug into your MB header. It sounds like you might be missing that one. You should let Coolermaster know....maybe they'll send you one.
You should have the 2 blue usb 3.0 cables that plug into the back and a usb 2.0 cable that plugs into your MB header coming off the front panel. I have the HAF X and that's what I have.
wierd because i check my manual the front panel only have 2 port to plug in which i can only pick either usb 3 or usb 2 do i have to buy some kinda of spilte for extra usb in front panel
does ur usb in the front panel both work usb 3 n usb 2
hey grumpp it mounts to the board but can u pull that wire in and out if you can please let me know i will go to microcenter and ask them for one or coolermaster or can i even buy one please let me know
i am having the same problem but i could not have something plugged into the motherboard correctly.. my usb2.0 work fine on the front panel but the 3.0. I could not find a connection for the cable coming from the front except to the usb on the left of the motherboard.. I have a gigabyte x58a-ud3r motherboard ,
