HAF XB Fans Configuration? Need HELP!!
johnvonmacz
729
So I'm getting myself a new build using this awesome looking case.
Here's the build by the way:
https://www.dropbox.com/s/rbfx6f58lpafy5s/Build.jpg
I wanna change the stock front fans and use the 2x bitfenix spectre blue 120mm instead for the Front. Then use 1x of the stock front 120mm fans for the Rear then the 1x Scythe Slip-Stream 120mm for the 212 EVO push-pull config. Then The 2x 80mm Silverstone Fans for the bottom and The 200mm Bitfenix for the Top.
But I don't know which will be the exhaust and which ones for intake? I'm so confused by this. Please Help me here. This'll be my first build. Thanks
Front 2 should be intake.
Sides should be intake.
Bottom should be intake
Back should be exaust
Top should be exaust
CPU Heatsink should blow air toward the back fan
The Powersupply fan should be bottom down, it has its own intake vent on the bottom of the case.
You may need a PWM splitter cable if the 120mm you want to bolt onto the hyper is a 4 pin CPU fan.
Thanks for both of your thoughts! Btw this will be a custom build. I mean like I pay a computer shop to build this for me. Do you think they will do the best possible Fan configuration for my PC?
If you give them specific instructions they should be able to setup your air flow however you want. I suggest reading that article I linked to for suggestions. I set my air flow up on my work PC exactly the way it described in the article, and my work PC never goes above 35'C even on heavy redraws.
Adding more fans isn't a big deal but how many you add is determined by the case mounts. Your motherboard powers up to four plus the CPU fan, and your power supply can support more with additional connectors.
Alright Could you please post here what type of Fan Configuration for HAF XB should I tell to the Computer Shop based on the Fans I chose? I posted my build in the OP. Like which fans should be intake and which ones will be the exhaust and the one for the push-pull config for the 212 EVO cooler based on the Fans I chose for my build. Thanks a lot
Ghetto picture, but what you want to go for.
