Hands On: NZXT’s Hue 2 RGB Kits And Accessories
You can do the same thin, for a fraction of the cost using an Arduino, open source software and chinese LED strips with much higher density. And it will sync with Gigabyte or Asus softwares by using their SDKs that NZXT REFUSES to release for developers. Proprietary RGB is just stupid.
These are really meant to be hidden in the corners of the case frame so that only the emitted light is seen. White reflects that light better.
