Hard disc help - hardware
TomShen
12
Hi guys,
My LG laptop is not working. Can I somehow rescue the data (songs, movies) without starting it. suppose getting the drive out and...What can I do?
Thanks a lot!
Hey there, Tom!
Sorry to hear about your laptop.
So first you will need to plug out the HDD carefully.
You will need either a SATA-to-USB cable or a dock station to plug it in another computer.
You can also just plug it in internally like any other SATA drive, if you have a rig at your sight.
If it's not damaged you will be able to access your data without a problem.
If it's unaccessible, you will need to perform a data recovery. Either a professional company, or you can try using some sort of utility that you should be able to find online to recover the data.
Here's a tutorial that might be useful: http://www.wikihow.com/Recover-Data-from-the-Hard-Drive-of-a-Dead-Laptop
Hope this helps. :)
SuperSoph_WD
be more specific
what does not working mean?
it wont power on,it powers on but wont load
but yes you can take the hard drive out and connect it to a pc to recover stuff--as long as the hard drive is not physically broken
can connect it internally,or in hard drive dock or with a usb cable
Hey there, Tom!
Hope this helps. :)
SuperSoph_WD
