Hard Disk 500 GB can be detected on PC but in TV not HELP!!
jvpenaflor515
i have a 500 gb seagate hard disk that can be detected with my pc but then when i plugged it on my tv it wont detect it please help me i need this
No idea. Waffle incoming.
The first thought which comes to mind is whether your hard disk is mechanical or flash based. If mechanical, then I would wonder whether the USB port of the TV can provide enough power to it; if it can't then it can't be read. This assumes it doesn't have an external power source.
Second thought is whether the USB port on TV is actually working. Try a USB stick and a small file, like a picture, to see if the port works.
Third thought is whether the TV requires storage to be formatted to a particular system in order to read it. Check your TV manual for information about support.
That's all I've got. I'm sure others will have actual advice.
Phillip Corcoran
Either the TV doesn't recognise the partition type on the hard drive, or you can only use a pen drive in the TV's USB port, not a hard drive.
Read the TV instruction book to see if it tells you what you plug in to the USB port, and what the partition type has to be.
