I use hard disk sentinel to check my hard disk status , it shows that Failure Predicted - Attribute: 1 Raw Read Error Rate, Errors occurred while reading raw data from a disk. Indicate problem with the disk surface or the read/write heads.
There are 7 weak sectors found on the disk surface. They may be remapped any time in the later use of the disk. Does that means I should replace this hard disk immediately ?
